Delete an entry from the unicast master table for a PTP clock instance. This command is available only for boundary clocks.
boundary |
Boundary clock. |
ordinary |
Ordinary clock. |
ipv4_address |
IPv4 address of a master to the local clock. |
vlan_name |
VLAN name to which the command is to be applied. |
N/A.
Use this command to delete an entry from the unicast master table for a PTP clock instance. This command is available only for boundary clocks.
The following command removes a static unicast master entry from boundary clock:
# configure network-clock ptp boundary delete unicast-master 192.168.1.1 vlan lpbk-gm
The following command removes a static unicast master entry from ordinary clock:
# configure network-clock ptp ordinary delete unicast-master 192.168.15.10 vlan lpbk-master
This command was first available in ExtremeXOS 15.1 Revision 2.
This command is available on 7520-48Y and 7720 platforms.
PTP commands can be used only with the Premier license pack.
